Dear Seafile Team. We are operating our cluster more than 3 years. Our Setup contains multiple Seafile nodes, backend nodes and central S3 storage for the data.
After some times we discovered, that the folder seafile-data and seahub-data are growing on each node more and more. We already moved the seafiel-data folder to a central nfs share to reduce the disk usage on the separate nodes.
Reference: Setup Seafile cluster with NFS - Seafile Admin Manual
After an inspection of the seahub-data folder we discovered, that ever node holds about 30GB of thumbnails.
Now the questions about it:
- Is it possible to use S3 for seafile-data and seahub-data as well? If yes, how can we configure it?
- If no, should we move the seahub-data folder to an nfs share as well and combine the thumbnails from all seafile nodes?
Thank you very much for your reply.
Beste Regards
