I use the following setting in seahub_settings.py with 6.2.5:
COMPRESS_CACHE_BACKEND = 'django.core.cache.backends.locmem.LocMemCache'
With 6.3.1 I get this error:
InvalidCacheBackendError: Could not find config for 'django.core.cache.backends.locmem.LocMemCache' in settings.CACHES
My temporary solution is to uncomment the setting and give permissions on /root/.cache/Python-Eggs to the seafile user.
Found the solution in:
https://github.com/haiwen/seahub/blob/master/seahub/settings.py
You have to add the cache to your seahub_settings.py:
CACHES = {
# Compatible with existing `COMPRESS_CACHE_BACKEND` setting after
# upgrading to django-compressor v2.2.
# ref: https://manual.seafile.com/deploy_pro/deploy_in_a_cluster.html
'django.core.cache.backends.locmem.LocMemCache': {
