SQL-Errors in fileserver.log
For some time now, I have been getting loads of entries like the following in fileserver.log
[2024-01-04 20:42:09] path /repo/folder-perm internal server error: Failed to get origin Repo perm table: Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘)’ at line 1
[2024-01-04 20:42:10] path /repo/locked-files internal server error: Failed to get origin Repo lock table: Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘)’ at line 1
Does anyone know what causes this? Weirdly enough, I do not see any client-side errors either with the seafile client or with the webinterface…
This is Seafile Pro 10.0.11 running on Ubuntu 20.04 LTS.
