Seafile 6.3.4 CE on Ubuntu 18.04 64bit x86 throws error messages during conversion from SQLite to MySQL accoding to the server manual. The server was previously running 6.2.5 CE with SQLite, and the upgrade to 6.3.4 CE with SQLite worked fine.
Here’s the log of the failed conversion from SQLite to MySQL:
user@myhost:~$ ./sqlite_to_mysql.sh
Start export ccnet data from user
Start export ccnet data from group
Done export ccnet data
Start export seafile data
Done export seafile data
Start export seahub data
syncDone export seahub data
user@myhost:~$ mysql -p
Enter password:
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 16
Server version: 5.7.25-0ubuntu0.18.04.2 (Ubuntu)
mysql> create database ccnet_db character set = ‘utf8’;
Query OK, 1 row affected (0.00 sec)
mysql> create database seafile_db character set = ‘utf8’;
mysql> create database seahub_db character set = ‘utf8’;
mysql> show databases;
| Database |
| information_schema |
| ccnet_db |
| seafile_db |
| seahub_db |
4 rows in set (0.01 sec)
mysql> use ccnet_db;
Database changed
mysql> source ce_ccnet_db.sql;
Query OK, 0 rows affected (0.00 sec)
Query OK, 0 rows affected, 1 warning (0.00 sec)
Query OK, 0 rows affected (0.03 sec)
Query OK, 0 rows affected (0.04 sec)
Query OK, 0 rows affected (0.02 sec)
mysql> source ccnet_db_data.sql;
ERROR 1054 (42S22): Unknown column ‘reference_id’ in ‘field list’
Query OK, 1 row affected (0.02 sec)
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘Group(group_id
,group_name
,creator_name
,timestamp
,type
, `parent_gro’ at line 1
Query OK, 1 row affected (0.01 sec)
Query OK, 0 rows affected (0.01 sec)
mysql> ^DBye
Any ideas?
