We’re getting ready to deploy Seafile Pro and are wanting to use logto io as a means of authentication.
Which would be a simpler integration method - OAuth2 or SAML?
Based on the query regarding SSO implementation with logto.io for Seafile Pro, here is an analysis of the integration methods available:
Seafile Pro supports both OAuth2 and SAML 2.0. For an integration with a modern identity provider like Logto, both are viable, but they differ in complexity and requirements:
OAUTH_* variables to seahub_settings.py .sp.crt, sp.key) and metadata URLs .xmlsec1 package (not needed for Docker) .Since Logto supports both protocols, OAuth2 is generally the simpler and recommended method for a quick deployment.
To use OAuth2 with Logto, you would configure the following in seahub_settings.py:
ENABLE_OAUTH = True
OAUTH_CLIENT_ID = "your-logto-app-id"
OAUTH_CLIENT_SECRET = "your-logto-app-secret"
OAUTH_REDIRECT_URL = 'https://your-seafile.com/oauth/callback/'
OAUTH_AUTHORIZATION_URL = 'https://your-logto-tenant.logto.app/oidc/auth'
OAUTH_TOKEN_URL = 'https://your-logto-tenant.logto.app/oidc/token'
OAUTH_USER_INFO_URL = 'https://your-logto-tenant.logto.app/oidc/me'
OAUTH_SCOPE = ["openid", "profile", "email"]
OAUTH_ATTRIBUTE_MAP = {
"sub": (True, "uid"),
"name": (False, "name"),
"email": (False, "contact_email"),
Note: Ensure the OAUTH_REDIRECT_URL matches exactly what is registered in the Logto console.
If your organization’s security policy requires SAML:
certs directory in your Seafile data volume and generate sp.crt/sp.key .https://your-seafile.com/saml2/metadata/) to configure Logto.seahub_settings.py with SAML_REMOTE_METADATA_URL (the metadata XML provided by Logto) and enable ENABLE_ADFS_LOGIN = True .For most users, OAuth2 is the simpler integration method because it avoids the overhead of managing local SP certificates and is easier to debug during initial setup .
