Storage Backend info on "My Libraries"
Hi all.
On v11 with multiple storage backends enabled, under " My Libraries" we could see the info regarding which backend a library belongs.
Under v12 this is no longer visible.
Does anyone know if it’s possible somehow to make this visible again?
Thank you.
Have you tried looking in the “Admin settings” at the “Libraries” section?
I used to have 2 backends in the past and I guess it was shown there.
Hi.
Unfortunately, there’s nothing there.
On v11 it was automatic as far as I remember. As soon as I added more than one backend, it would add that “Storage Backend” column on the Web UI.
But on v12 this is not happening, as seen in my previous screenshots, and there’s no setting anywhere that I can find to turn this on.
