dear seafile community!
is it possible to store libraries to different paths then the default path?
i would like to use different disks/filesystems for libraries because i want to run different backup strategies…
thanks in advance
thanks in advance
iirc seafile does not limit what directories you can sync as libraries. You can always use symbolic links though.
thanks - use of symbolic links would have been my last resort. i was hoping there is a built in function to manage this.
