I am trying to upgrade a SeaFile Pro install from 6.0.12 to 6.1.9 and am stuck at the step where you run the script from the upgrade folder.
The last version in the folder is upgrade_6.0_6.1.sh, if I run that it gets stuck at ‘migrating avatars’. I reverted to a previous snapshot and figured i’d ask here what the correct process is before I tried again.
Same Problem here. I followed exactly upgrade manual and started.
I firstly had Problems to turn off seahub as it still was running so i found pids and killed them. Than the Update SCript worked until migrating Avatars.
