Is it possible to sync WIndows symobolic links as links? The default behavior seems to be that Windows symbolic links sync as unusable empty files instead of being retained as links.
I have seen some discussion of this problem in the forums, but haven’t seen a conclusive answer.
Thanks for your reply. May I make a request for this to be included in a future release? Symlinks are used by some applications, and without the ability to sync those (as links, not files), Seafile’s usefulness is diminished.
Complicating matters is that Seafile syncs the symlinks as empty files, so it’s not even possible to manually work around this. At minimum, is it possible for Seafile to simply ignore the symlinks instead of copying them as empty files?
Please let us know when the symbolik link on Windows too will be sorted out.
It is getting really frustrating to copy lots of files in different directories.
Any news on that?
Thanks, Murz. Symlink support for Windows is still needed. Based on the number of comments in this forum and others, symlink support seems important to significant number of users. Still hoping it gets implemented soon.
