Hi hi, I’ld like to sync my dotfiles inside my homedir between all my server’s
I’m running two dozen or so machines on which I’ld like to see the same .tmux.conf etc. pp., I’ve this up fine for my three different Workstations but I’ld like to install it to the server’s too, specifically for at least three or four management hosts…
I’ve succesfully managed to get a voyage-linux machine running from SD with readlony homedir to sync my .ssh with my Seafile Server… But I don’t need the whole share on that machine I only want a few linux specific file’s sync’d to those machines.
Here’s what I’ve done so far:
Install: sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 8756C4F765C9AC3CB6B85D62379CE192D401AB61 echo deb http://dl.bintray.com/seafile-org/deb jessie main | sudo tee /etc/apt/sources.list.d/seafile.list sudo apt-get update sudo apt-get install seafile-cli
then I’ve created some tmpfs setting’s specific to voyage-linux, after which I did this:
and finally I ran: seaf-cli start -c /var/lib/seafile/ seaf-cli download -l 6d3d746e-1d74-4d53-9bb6-cceFOOBAR -s https://cloud.mydomain.de -c /var/lib/seafile/ -d /var/lib/seafiledatadir/ -u USERNAME seaf-cli status -c /var/lib/seafile/
but there doesn’t seem to be a way to sync a subdir of the library with the CLI client… Tried to add the folder Path to library ID like: 6d3d746e-1d74-4d53-9bb6-cceFOOBAR/CONSOLE
But I get a 404 error in the Seafile.log when I do so…
Is there really no way to do that in the CLI client? I’m doing this already with other folder’s using the GUI client…
Greetz
Mirco
P.S.: My first posting here, all my post’s before have been on the german forum.
Just found this post trying to figure out how to do the same thing. This is not working for me, the ID provided is the exact same as the main library itself.
Is there a new way of syncing a folder within a library, instead of having to sync the entire library?
I’m afraid the procedure no longer works. These is no longer URL prompt when browsing cloud storage in GUI. Any idea how to get subfolder ID to sync with seaf-cli?
Even right click on subfolder and generate-internal-link, which is
df0ea1bc-9905-4637-a1df-5b4dbacb14d0
isn’t right one. seaf-cli generate error when trying to sync it.
I was using procedure until today so I know it was working. Seems there was update on GUI which removed URL…
An easy way to get the ID is to create a dummy user and then share the folder in question with that user. Then in the admin panel → users → dummy user → shared libraries you’ll find that shared folder along with its ID when looking at the network inspector in the browser developer tools.
