I’d like to move a running 5.1.4 install to a new machine. Rsynced everything over and untarred the new version 10. Now wanting to run the upgrade scripts: upgrade_5.1_6.0.sh, upgrade_6.0_6.1.sh, … in order.
Problem, the new system has no python2. Can I just replace the PYTHON in the upgrade script? After all, the module it calls is python3 already? What about the seafile-server-latest link, where should it point at?
Further steps, using the sqlite database, not using memcached, on this debian 12 system, two packages satisfy all that seafile requires to operate (properly, from first looks):
There is no need to modify any file at all: Just prepend PYTHON=/usr/bin/python3 before the call to the various upgrade scripts. They then will use the python executable that you specify. The line you quoted works when the shell working directory is the same as where the upgrade scripts live.
