I am using the latest version of Seafile pro server (6.1.4) and I am having a problem.
I have generated an upload link for a library. Whenever someone tries to upload something, it will not upload. It shows uploading status without any percentage change. Small files upload fine. Larger files stay like this.
See the attached picture
Can someone help me troubleshoot? It worked fine with previous versions.
Thank you
Nginx vhost config:
listen 80;
server_name files.domain.com;
return 301 https://$server_name$request_uri;
listen 443 ssl http2;
ssl on;
ssl_certificate /etc/letsencrypt/live/files.domain.com/fullchain.pem; # path to your cacert.pem
ssl_certificate_key /etc/letsencrypt/live/files.domain.com/privkey.pem; # path to your privkey.pem
include /etc/letsencrypt/options-ssl-nginx.conf;
server_tokens off;
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
fastcgi_read_timeout 36000;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /var/www/files.domain.com/seafile-server-latest/seahub;
location /seafdav {
fastcgi_pass 127.0.0.1:8080;
proxy_request_buffering off;
seafile.log
[07/17/2017 08:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 09:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 10:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 11:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 12:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 01:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 02:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 03:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 04:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 05:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 06:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 07:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 08:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 09:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 10:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/17/2017 11:47:25 PM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 12:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 01:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 02:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 03:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 04:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 05:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 06:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 07:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 08:47:25 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 09:46:59 AM] Disconnected from daemon
[07/18/2017 09:47:12 AM] …/common/mq-mgr.c(61): [mq client] mq cilent is started
[07/18/2017 09:47:12 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 10:13:15 AM] Disconnected from daemon
[07/18/2017 10:13:22 AM] …/common/mq-mgr.c(61): [mq client] mq cilent is started
[07/18/2017 10:13:22 AM] filelock-mgr.c(917): Cleaning expired file locks.
[07/18/2017 10:22:27 AM] …/common/mq-mgr.c(61): [mq client] mq cilent is started
[07/18/2017 10:22:27 AM] filelock-mgr.c(917): Cleaning expired file locks.
