The upload got to about 2.9GB and stopped again. The last include in the config file points to a file that doesn’t exist. So nothing there.
The one marked #Proxy! does exist. I would have included it before, but I hadn’t figured out to what relative path it was referring. I did now (it’s in /etc/nginx), here it is:
add_header X-Served-By $host;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Scheme $scheme;
proxy_pass $forward_scheme://$server:$port$request_uri;
I’ll paste the other files here as well. Sorry to not be of much help, I don’t really understand nginx configuration that much:
letsencrypt-acme-challenge.conf
# Rule for legitimate ACME Challenge requests (like /.well-known/acme-challenge/xxxxxxxxx)
# We use ^~ here, so that we don't check other regexes (for speed-up). We actually MUST cancel
# other regex checks, because in our other config files have regex rule that denies access to files with dotted names.
location ^~ /.well-known/acme-challenge/ {
# Since this is for letsencrypt authentication of a domain and they do not give IP ranges of their infrastructure
# we need to open up access by turning off auth and IP ACL for this location.
auth_basic off;
auth_request off;
allow all;
# Set correct content type. According to this:
# https://community.letsencrypt.org/t/using-the-webroot-domain-verification-method/1445/29
# Current specification requires "text/plain" or no content header at all.
# It seems that "text/plain" is a safe option.
default_type "text/plain";
# This directory must be the same as in /etc/letsencrypt/cli.ini
# as "webroot-path" parameter. Also don't forget to set "authenticator" parameter
# there to "webroot".
# Do NOT use alias, use root! Target directory is located here:
# /var/www/common/letsencrypt/.well-known/acme-challenge/
root /data/letsencrypt-acme-challenge;
# Hide /acme-challenge subdirectory and return 404 on all requests.
# It is somewhat more secure than letting Nginx return 403.
# Ending slash is important!
location = /.well-known/acme-challenge/ {
return 404;
ssl-ciphers.conf
ssl_session_timeout 5m;
# intermediate configuration. tweak to your needs.
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers 'ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384';
ssl_prefer_server_ciphers off;
assets.conf
location ~* ^.*\.(css|js|jpe?g|gif|png|webp|woff|eot|ttf|svg|ico|css\.map|js\.map)$ {
if_modified_since off;
# use the public cache
proxy_cache public-cache;
proxy_cache_key $host$request_uri;
# ignore these headers for media
proxy_ignore_headers Set-Cookie Cache-Control Expires X-Accel-Expires;
# cache 200s and also 404s (not ideal but there are a few 404 images for some reason)
proxy_cache_valid any 30m;
proxy_cache_valid 404 1m;
# strip this header to avoid If-Modified-Since requests
proxy_hide_header Last-Modified;
proxy_hide_header Cache-Control;
proxy_hide_header Vary;
proxy_cache_bypass 0;
proxy_no_cache 0;
proxy_cache_use_stale error timeout updating http_500 http_502 http_503 http_504 http_404;
proxy_connect_timeout 5s;
proxy_read_timeout 45s;
expires @30m;
access_log off;
include conf.d/include/proxy.conf;
block-exploits.conf
## Block SQL injections
set $block_sql_injections 0;
if ($query_string ~ "union.*select.*\(") {
set $block_sql_injections 1;
if ($query_string ~ "union.*all.*select.*") {
if ($query_string ~ "concat.*\(") {
if ($block_sql_injections = 1) {
return 403;
## Block file injections
set $block_file_injections 0;
if ($query_string ~ "[a-zA-Z0-9_]=http://") {
set $block_file_injections 1;
if ($query_string ~ "[a-zA-Z0-9_]=(\.\.//?)+") {
if ($query_string ~ "[a-zA-Z0-9_]=/([a-z0-9_.]//?)+") {
if ($block_file_injections = 1) {
return 403;
## Block common exploits
set $block_common_exploits 0;
if ($query_string ~ "(<|%3C).*script.*(>|%3E)") {
set $block_common_exploits 1;
if ($query_string ~ "GLOBALS(=|\[|\%[0-9A-Z]{0,2})") {
if ($query_string ~ "_REQUEST(=|\[|\%[0-9A-Z]{0,2})") {
if ($query_string ~ "proc/self/environ") {
if ($query_string ~ "mosConfig_[a-zA-Z_]{1,21}(=|\%3D)") {
if ($query_string ~ "base64_(en|de)code\(.*\)") {
if ($block_common_exploits = 1) {
return 403;
## Block spam
set $block_spam 0;
if ($query_string ~ "\b(ultram|unicauca|valium|viagra|vicodin|xanax|ypxaieo)\b") {
set $block_spam 1;
if ($query_string ~ "\b(erections|hoodia|huronriveracres|impotence|levitra|libido)\b") {
set $block_spam 1;
if ($query_string ~ "\b(ambien|blue\spill|cialis|cocaine|ejaculation|erectile)\b") {
set $block_spam 1;
if ($query_string ~ "\b(lipitor|phentermin|pro[sz]ac|sandyauer|tramadol|troyhamby)\b") {
set $block_spam 1;
if ($block_spam = 1) {
return 403;
## Block user agents
set $block_user_agents 0;
# Disable Akeeba Remote Control 2.5 and earlier
if ($http_user_agent ~ "Indy Library") {
set $block_user_agents 1;
# Common bandwidth hoggers and hacking tools.
if ($http_user_agent ~ "libwww-perl") {
if ($http_user_agent ~ "GetRight") {
if ($http_user_agent ~ "GetWeb!") {
if ($http_user_agent ~ "Go!Zilla") {
if ($http_user_agent ~ "Download Demon") {
if ($http_user_agent ~ "Go-Ahead-Got-It") {
if ($http_user_agent ~ "TurnitinBot") {
if ($http_user_agent ~ "GrabNet") {
if ($block_user_agents = 1) {
return 403;
force-ssl.conf
if ($scheme = "http") {
Those should be all. Since I have located the log file now, I’ll try to upload with the log open, and see what I find.
