‘Moviepy’ and ‘ffmpeg’ are installed inside docker. After restart the docker, i can not open the seafile, both web and app,if delete above settings from seahub_settings.py’,it works well again.Why? What is wrong?
you may change it but need to use a correct path as in your case it would be
THUMBNAIL_ROOT = ‘/Shared/seafile/seahub-data/thumbnail/’
or shared with a lower s
