Hi. I have SeaFile 9.0.0 deployed, I normally sync files from a PC and from an Android device via WebDAV, but for iOS devices I can’t find a normal application with automatic backup of photos and videos with connection to a WebDAV server. The Seafile Pro client for IOS itself syncs with errors.
Please share which sync apps do you use?
I have Android,
I’ve tried a few different tools
Syncthing works but sometimes is annoying to connect.
FolderSync Pro works (android)
MetaCtrl Autosync works (android)
For iOS I don’t know if this one is good but it has a high rating: Sync Folders Pro on the App Store
I’m using the Seafile app on iOS and haven’t seen any errors.
Thanks for the answer) On android, I also use sync folder and I don’t see any problems)
Have you tried shooting a 500 MB video? Does it sync automatically without problems on iOS?
