Hi…
I recently set up https, but when I try to go to https: // IP: 8080 / seafdav I get the error “ERR_SSL_PROTOCOL_ERROR”
How can I solve? thanks
Hi…
I use the URL https://mydomain.com/seafdav to access Seafile via WebDAV. My setup follows the Seafile Manual using Nginx and Ubuntu 16.
Because you try access it directly (over http), but the Port is proxied by Apache or nginx. You have to acces over https://yourdomain.con/seafdav
. Or do you have a setup without a reverse proxy?
I use apache2…on debian
Even then he’s right. Can you access it under this subfolder?
