Login into WebDAV does not work using the ‘login id’ defined in the admin interface.
Currently only contact email and register email can be used. We’ll add support for login ID later.
I discovered this by trial and error. Could this limitation please be added to the webdav section of the documentation?
Curious if there has been any update on this or if it is on the roadmap? I found this issue today when trying to use WebDav for the first time. I believe I have a third-party app that doesn’t support “@” in the user id, so I am unable to use the program with Seafile WebDav (logging a bug with that application also).
This is not added yet. We add it to the plan for version 10.
Thank you. Is that targeted for Q4 this year?
