Hi.
I have problem with my WebDav on SeaFile 10.0.1.
I configured it as in the manual.
seafdav.conf:
[WEBDAV] enabled = true port = 8080 workers = 5 fastcgi = false share_name = /seafdav timeout = 1200
Nginx conf:
location /seafdav {
proxy_passhttp://172.30.28.2:8080/seafdav;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
client_max_body_size 0;proxy_set_header Destination "http:$nossl_destination"; access_log /var/log/nginx/seafdav.access.log seafileformat; error_log /var/log/nginx/seafdav.error.log; }
After entering cloud.temp.com/seafdav
Everything seems normal but when I try to go to the scan folder the path changes to cloud.temp.com/scan and I get the message “Unfortunately, the page you requested could not be found”. The path is obviously wrong, missing /seafdav.
In my previous installation with SeaFile Server ver. 9 with the same configuration everything worked fine.
Please help me solve this problem.
Regards
Dawid
