Hello-
Hopefully a simple quick question.
What folder do I put my robots.txt file in?
Thanks!
Hello-
Thanks!
Webroot?
Seafile comes with robots.txt. It is in the seahub/seahub/templates/robots.txt, which you can modify. By default it is set to
User-agent: *
Disallow: /
Thank you, I found it in seafile-server-6.2.3/seahub/seahub/templates
Is this file being used (will search bots see the txt)? Or, does it need to be moved somewhere to become useful?
Thanks again,
It is in use. No need to move.
