Is there any possibility getting a white label client for windows?
Or is it general to use the client with the seafile label / logo?
Hi bilateral,
welcome to the Seafile Community Forum!
As for your question: The windows client - the sync client - is open source. Just help yourself. You find it on Github: https://github.com/haiwen/seafile-client
Ralf
But the build process isn’t documented.
I’m trying to run the solution, but it cannot find these source files:
Are these dependencies? Where can I get them?
You can consult @Speicherbox
