In my installation of Seafile Server every Directory has a “download” icon, but when clicking it an error is thrown:
“Size is too large”.
Does it try to zip it?
My users are confused, i have to tell everyone to only download files.
Can the Directory-download function be turned off?
thx
Large folders cannot be download. Your server may be getting slow if an user tries to zip a 300GB folder.
But you can set the maximal size for folder, which can be downloaded.
See the manual: https://manual.seafile.com/config/seafile-conf.html
[fileserver]
# Set maximum upload file size to 200M.
max_upload_size=200
# Set maximum download directory size to 200M.
max_download_dir_size=200
oh thanks, will try that. i hope the download icon goes away if size exceeds setting.
