If you share a folder with a public link (in the example First_Folder) and there are other folders in it (in the example Second_Folder1), then if you click on Second_Folder1, the path should be: Current path: First_Folder / Second_Folder1. Instead, the path is Current path: Second_Folder1 / Second_Folder1
The base folder is thus mistakenly given the name of the current folder. The link, however, is correct.
Server version: CE 7.0.4
