Hello Seafile Community!
I’m excited to announce the beta release of our new Seafile Zapier app! This integration allows you to automate your Seafile workflows and connect them with hundreds of other apps on Zapier.
Features
Our beta version includes the following capabilities:
Triggers
- New File
- New or Updated File
- New Tagged File
Actions
- Download a file
- Create Folder
- Create Shared Link
- Create Text File
- Delete File
- Delete Folder
- Move File
- Rename File
- Upload File
- API Request (Beta)
Searches
How to Join the Beta
To get access to this beta version, simply click on the following invite link: Login | Zapier
We Need Your Feedback!
As this is a beta release, your input is crucial in helping us improve and refine the app. We encourage you to:
- Test the various triggers, actions, and searches
- Try creating different Zaps with your favorite apps
- Share any bugs, issues, or suggestions you encounter
Your feedback will be invaluable in ensuring that the final release meets the needs of our community.
How to Provide Feedback
Please share your experiences, suggestions, or report any issues in this forum thread. We’ll be actively monitoring your comments and are eager to hear your thoughts! Thank you for your support in making the Seafile Zapier integration even better. Happy automating!
Best regards
Christoph Dyllick-Brenzinger
Here are four example Zapier workflows that leverage the available Seafile actions and triggers, providing value for users:
Save email attachments to Seafile
Trigger: New E-Mail with Attachment
Action: Upload File to Seafile
Value: Automatically save file attachments to Seafile to keep a Backup
Automatic File Backup
Trigger: New or Updated File in Dropbox
Value: Automatically backs up important files from Dropbox to Seafile, ensuring data redundancy and easy access across platforms.
Tagged File
Trigger: New Tagged File in Seafile
Action: Move File in Seafile to a specific folder
Value: Automatically organizes files into specific folders based on their tags, maintaining a clean and structured file system.
Collaborative Document Workflow
Trigger: New Invoice in a specific Seafile folder
Actions: Create Download Link and send Email (via Gmail) with the shared link to the customer.
Value: Streamlines collaboration by automatically sharing new documents with team members or customers.
For sure there are many more possible workflows, that you could build with Zapier. Have fun…
It’s great but it would be much better if it were available on Make.com, Zappier is far too expensive.
Thanks for your feedback.
Platforms
In my opinion, these are the three decisive platforms:
Status
- Zapier (Beta Version) is now available.
- I have already created a n8n Community Node.
- I already started to work on a Make.com Integration shortly.
Best regards
Christoph from datamate
Great, these are the best-known and most recognized tools. I’ve already set up an alert when a new file is added that sends a message to a discord.
Do you think it would be possible to have a single alert when several files are added instead of having one per file, as this consumes a lot of operations if several files are added.
I’m looking forward to integration with Make.com.
Update : I didn’t know that n8n could be self-hosted so I will try your integration with n8n
Hey,
it is not the task of a zapier trigger to merge multiple trigger events into one action. With n8n you could use “merge”. With Zapier, I would recommend, that you write the trigger events into a zapier table or “SeaTable” and then have another zap to inform about new files…
Best regards
Christoph
The Seafile Zapier App is nearly ready and will be published soon. Now is the perfect time for testing and final feedback.
The invitation link is still the same: Test now the Seafile Zapier App.
