403 Forbidden, CSRF verification failed. Referer checking failed, does not match trusted origins
Greetings,
I could log in fine before I did the Let’s Encrypt SSL. Now I get to the log-in page which is encrypted (green padlock) but when I put in my admin name & password I end up at the 403 page.
The error message is 403 Forbidden, CSRF verification failed. Referer checking failed https://my.server.net/accounts/login/?next=/ does not match any trusted origins.
This is a new install: Debian 9. Seafile 6.3.4 CE, Nginx 1.10.3, MariaDB
I’m not new to Seafile but obviously I’m missing something,
My nginx config and seahub_settings.py are below:
  listen 80;
  server_name my.server.net;
location '/.well-known/acme-challenge' {
    default_type "text/plain";
    root /opt/certbot-webroot;
  listen 443;
  ssl on;
  ssl_certificate /etc/letsencrypt/live/my.server.net/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/my.server.net/privkey.pem;
         proxy_read_timeout 1200s;
    proxy_connect_timeout 36000s;
    proxy_read_timeout 36000s;
    proxy_send_timeout 36000s;
  location /seafdav {
    fastcgi_pass 127.0.0.1:8080;
    fastcgi_param HTTPS on;
My seahub_settings.py
# -*- coding: utf-8 -*-
SECRET_KEY = "mysecretkey"
FILE_SERVER_ROOT = 'https://my.server.net/seafhttp'
SITE_BASE        = 'https://my.server.net'
DEBUG            = True
DATABASES = {
    'default': {
        'NAME': 'seahub-db',
        'USER': 'seafile',
        'PASSWORD': 'myseafiledbpassword',
        'HOST': '127.0.0.1',
        'PORT': '3306'
Any help would be appreciated.
Thanks,
Mark
DUPLICATE
Please search through the forum for similar issues before starting a new thread.
Already have.
Chrome Problem only, N/A, no answer provided, and my issue exists in all browsers
No custom port in my setup, N/A
Looked liked a potential solution, but “replace proxy_set_header Host $host:$server_port; with proxy_set_header Host $host; in nginx config”. did not provide a working solution, after inputting credentials end up at a white loading screen" with spinning orb. So it did make the error go away but not a usable fix. Maybe it’s a part of the solution, TBD
Have to change back to proxy_set_header Host $host:$server_port; to stop.
If I missed anything please let me know. Otherwise help, would be greatly appreciated!
Thanks,
Mark
Hi All,
i upgraded my Docker install to latest (6.3.4) and since then i have the same CSRF Problem es described here in ths thread.
In my nginx conf i have proxy_set_header Host $host; automaticaly set, since i’m using the latest Docker image. But still i get the CSRF.
I searched the forum an google and try to place a
CSRF_TRUSTED_ORIGINS = ‘myserver’ in the seahub_settings.py. To no efect :frowning:
The sugeted solution seafile issues 2118 to add the line
proxy_pass_header Set-Cookie; in the nginx config as well didn’t solve it…
By now I’m at a loss what else i could try.
Anny hints help from anybody here??
Thanx
HBAU
try with
CSRF_TRUSTED_ORIGINS = ['myserver.tld']
I am late to this thread, but just experienced this problem. Running Apache as the box’s primary web server, then have Seafile running in Docker with NGINX using alternative ports 1080 and 8443.
I do have Apache do a redirect
RewriteRule ^ https://%{SERVER_NAME}:8443%{REQUEST_URI} [END,NE,R=permanent]
This particular grief was SOLVED by changing the NGINX virtual server file:
Added the alternative port to the proxy_set_header config.
listen 1080;
snip/snip
listen 8443 ssl;
snip/snip
    proxy_pass http://127.0.0.1:8000/;
    proxy_read_timeout 310s;
proxy_set_header Host $host:8443;
snip/snip
I had to use
CSRF_TRUSTED_ORIGINS = ['https://myserver.tld']
which seems to be needed by django 4.
stock seafile (docker) and nginx proxy manager here.
worked for me
CSRF_TRUSTED_ORIGINS worked for me too, but I would like some more details. Is this just a work-around that should be removed when this bug is fixed, or is this a new config option that should be set when deploying servers from now on?
Please check our FAQ: Seafile FAQ & Known-Issues
In you modified the port mapping, the origin field in the HTTP header received by Django is http{s}://{ip_or_domain}:20080 and the host field in HTTP header is {ip_or_domain} without the custom port. This mismatch results in a CSRF error.
However, in the original HTTP request sent by the browser, the origin and host fields are both http{s}://{ip_or_domain}:20080 . The mismatch is caused by the wrong Nginx setting.
You can correct it by changing Nginx config to the following:
The old one is proxy_set_header Host $host; , which does not pass the port part to Django.
please where i need to add this ?
For the future, if you don’t want to have such CSRF verification errors, I would recommend that you use this new deployment method:
https://datamate-rethink-it.github.io/seafile-admin-docs/
This is much simpler and it automatically sets required parameters like CSRF_TRUSTED_ORIGINS.
