Nothing big, but the markup of the sidebar buttons in the markdown/text editor changed in 8.0 and therefore the Seamate CSS renders them hard to see.
Hey everybody,
seamate now supports the following seafile versions:
- 7.1.9PE
- 7.1.12PE
- 7.1.14PE
- 7.1.17PE
- 7.1.18PE
- 7.1.19PE
- 7.1.5CE.
The links is as always: https://datamate.org/seafile/seamate .
SeaTable 8 Support will be added shortly.
Best regards
Christoph
Hey Everybody,
seamate is now capable to generate css files for Seafile 8.0.x PE and CE.
You can find seamate at this url: https://datamate.org/seafile/seamate
Best regards
Christoph
Hey everybody,
Seamate now supports the following Seafile versions:
- 9.0.7PE
- 9.0.4PE
- 8.0.17PE
- 9.0.7CE
- 9.0.4CE
The link is as always: https://datamate.org/seafile/seamate .
I also resolved the problem @Martin mentioned with the icons in the markdown editor.
Best regards,
Christoph
Is an update for version 10 available?
The css for version 9 works quite good, but there is a bug in drop down lists, e.g. in the my groups in the left navigation. when a group is selected, the last item in the list disappears.
Are there plans to add compatibility with version 10?
There is a bug with drop down list (example: Share Admin → Links item disappear)
Hey everybody,
- 10.0.9 PE (should work with all 10.0.x Versions)
- 10.0.1 CE
The link is as always: https://datamate.org/seafile/seamate.
I also resolved the problem @z3ky and @epokora mentioned.
Best regards
Christoph
Has anyone looked into changing the colors of the folders? I know they’re just images, so they can be modified and replaced, but maybe there’s a smarter and more update-resistent method?
Similar happens since v11.0.4
The last item in a list, e.g. of groups, disappears after one item has been selected.
