I am facing issue in seahub start.
and it is showing below mentioned message
./seahub.sh start
Error:Seahub failed to start.
so I have tried ./seahub.sh start-fastcgi
File “/home/ayush/projects/kaka/seafile-server-7.1.4/seahub/manage.py”, line 10, in
File “/home/ayush/projects/kaka/seafile-server-7.1.4/seahub/thirdpart/django/core/management/init.py”, line 364, in execute_from_command_line
utility.execute()
File “/home/ayush/projects/kaka/seafile-server-7.1.4/seahub/thirdpart/django/core/management/init.py”, line 338, in execute
django.setup()
File “/home/ayush/projects/kaka/seafile-server-7.1.4/seahub/thirdpart/django/init.py”, line 27, in setup
File “/home/ayush/projects/kaka/seafile-server-7.1.4/seahub/thirdpart/django/apps/registry.py”, line 85, in populate
app_config = AppConfig.create(entry)
File “/home/ayush/projects/kaka/seafile-server-7.1.4/seahub/thirdpart/django/apps/config.py”, line 94, in create
module = import_module(entry)
File “/usr/lib/python3.5/importlib/init.py”, line 126, in import_module
File “”, line 986, in _gcd_import
File “”, line 969, in _find_and_load
File “”, line 956, in _find_and_load_unlocked
ImportError: No module named ‘captcha’
Kindly help me it’s quite urgent , and I want to know that how the synchronization works in seafile between different devices over different platforms like Android, MAC, Windows and Linux
