baz
January 16, 2024, 10:05pm
I see on various posts that people are using some sort of automatic nginx configuration. For example a user mentions it here: Seafile In Docker - Trigger Nginx Config Regeneration .
I didn’t find anywhere in the instructions to do this, only the manual install: HTTPS with Nginx - Seafile Admin Manual
How does one have nginx automatically configured?
Barolo
January 17, 2024, 7:49am
They use docker deployment .
The seafile container provides its own nginx server, which is automatically configured with the environment variables declared in the compose file.
baz
January 17, 2024, 11:51am
3
Thank you, that’s very helpful
Any idea if re-installing seafile ontop of an existing seafile is possible? I was thinking of keeping seafile-data and the mysql folder but nuking the confs and the rest to start over.
Barolo
January 17, 2024, 3:54pm
4
Yes it is, but it’s not what I would recommend, unless you have plenty of data and/or users.
Wiping everything and then reupload all data is more friendly.
