Call me crazy but I went from version 11 to 12 and then to 13 in one day. Weird thing is my mobile sync apps work fine, I can login and all but only when I try to login via WEB I get this error
[2025-09-24 10:39:25] [WARNING] seahub.auth.views:160 login Login attempt limit reached, show Captcha, email/username: jochen@example.com, ip: 2001:1111:2222:29::1042, attempts: 5
[2025-09-24 10:39:34] [WARNING] seahub.auth.views:160 login Login attempt limit reached, show Captcha, email/username: jochen@example.com, ip: 2001:1111:2222:29::1042, attempts: 6
[2025-09-24 10:39:42] [WARNING] seahub.auth.views:160 login Login attempt limit reached, show Captcha, email/username: jochen@example.com, ip: 2001:1111:2222:29::1042, attempts: 7
[2025-09-24 10:41:12] [WARNING] seahub.auth.views:172 login Login attempt limit reached, show Captcha, ip: 2001:1111:2222:29::1042, attempts: 7
[2025-09-24 10:41:17] [WARNING] seahub.auth.views:160 login Login attempt limit reached, show Captcha, email/username: jochen@example.com, ip: 2001:1111:2222:29::1042, attempts: 8
[2025-09-24 10:46:41] [WARNING] seahub.auth.views:160 login Login attempt limit reached, show Captcha, email/username: jochen@example.com, ip: 2001:1111:2222:29::1042, attempts: 9
[2025-09-24 11:00:14] [ERROR] django.request:246 log_response Internal Server Error: /api/v2.1/admin/users/jochen@example.com/share-links/
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/django/core/handlers/exception.py", line 55, in inner
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/django/core/handlers/base.py", line 197, in _get_response
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/django/views/decorators/csrf.py", line 56, in wrapper_view
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/django/views/generic/base.py", line 105, in view
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/rest_framework/views.py", line 509, in dispatch
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/rest_framework/views.py", line 469, in handle_exception
self.raise_uncaught_exception(exc)
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/rest_framework/views.py", line 480, in raise_uncaught_exception
raise exc
File "/opt/seafile/seafile-server-13.0.8/seahub/thirdpart/rest_framework/views.py", line 506, in dispatch
File "/opt/seafile/seafile-server-13.0.8/seahub/seahub/api2/endpoints/admin/users.py", line 1658, in get
link_info = get_user_share_link_info(fs)
File "/opt/seafile/seafile-server-13.0.8/seahub/seahub/api2/endpoints/admin/users.py", line 294, in get_user_share_link_info
data['size'] = seafile_api.get_file_size(repo.store_id,
File "/opt/seafile/seafile-server-13.0.8/seafile/lib/python3/site-packages/seaserv/api.py", line 202, in get_file_size
return seafserv_threaded_rpc.get_file_size(store_id, version, file_id)
File "/opt/seafile/seafile-server-13.0.8/seafile/lib/python3/site-packages/pysearpc/client.py", line 127, in newfunc
return fret(ret_str)
File "/opt/seafile/seafile-server-13.0.8/seafile/lib/python3/site-packages/pysearpc/client.py", line 11, in _fret_int
raise SearpcError(dicts['err_msg'])
pysearpc.common.SearpcError: Invalid file id
[2025-09-24 11:01:19] [WARNING] django.request:246 log_response Unauthorized: /api2/repos/
[2025-09-24 11:15:04] [WARNING] django.request:246 log_response Unauthorized: /api/v2.1/repos/3960c580-bd61-412f-8bce-02e55be70175/dir/
[2025-09-24 15:30:57] [WARNING] seahub.auth.views:160 login Login attempt limit reached, show Captcha, email/username: jochen@example.com, ip: 2001:3333:4444:fe:12ff:e0ff:fe4e:51d1, attempts: 5
[2025-09-24 15:38:51] [WARNING] django.request:246 log_response Not Found: /.git/config
I created a new superuser via the reset-admin.shand with it I can login. I cannot allow to loose my shares and stuff because when I migrated my data to a new user. What I saw in DB is that my failing user is just carrying the login email in the email field in the EmailUser column.
The resetted and working user is like this: 6c91c112b3684f9fa691641e2adeiycc3@auth.local
Anyone got an idea what’s going on? I read something about native authentication and stuff but my mariadb 10.11 seems to have that configured for the user I login to the DB with. Running in podman containers btw.
Thanks so much
