I really like the OnlyOffice-Integration thanks very much for that!
But I noticed after editing .odt-files it’s not possible to open them again with LibreOffice. Trying to open shows
.docx-files are working without problems.
Not sure if this is a OnlyOffice bug or a Seafile one or a misconfiguration.
Can someone please test this behavior and confirm or disprove?
Thanks
Only office does not support ODF file formats. They only recently open sourced their software and were primarily competing against Google Docs/365. Might be worth sending them an email to request support. But ODT etc won’t work with OO.
Hi Clouds,
sorry but to me it seems as if that OnlyOffice support odt file files.
Please see GitHub
Where did you get an information?
@Simsala i can confirm the problem.
If i choose no at repair question and confirm the next error message, the document will open with all change i made over web.
The problem unfortunately seems to have to do with seafile. That’s what I got from the OnlyOffice-Forum:
We tried to reproduce the issue but have no luck.
We suppose that file corrupting has occurred not on our side.
Unfortunately we cannot say what is the reason of that behavior
Hello everybody!
I have found this instruction how to connect the ONLYOFFICE Document Server to Seafile, but i see there is a mistake in URL which leads to ONLYOFFICE Community Server but not to ONLYOFFICE Document Server - PLEASE make it correct Admins! Anyway please tell me Does this istruction work?
@simsala Apologies for the Fake News! I’m pleasantly surprised. I had read on a forum, I think ycombinator, that it didn’t support odt. Looks like I misplaced my trust and almost spread a lie. Thanks for correcting.
@xiez
please check the OnlyOffice api menual
The key parameter is limit to 20 chars. In my test environment Seafile used a key with 40 chars.
Maybe this can cause the issue?
sorry @mdovey but that’s wrong. The fix is included in the current beta download files. I have checked this now.
I also tested with a key length of 20 chars(key = obj_id[20:]), unfortunately with the same result.
Ah, my bad, I misread the update diff, and thought
doc_key = gen_token(10)
was the new code not the old one!
The new code (key = obj_id) causes an additional problem in that it generate keys of all 0s for empty\zero length files (such as those created by selecting New Document). This causes problems (due to a key clash) if you open two different empty files at the same time or in quick succession.
Try reverting to the older gen_token(10) code (or even gen_token(20) )
