Hello.
I want to integrate Onlyoffice in Seafile.
I have installed Onlyoffice with docker.
The Nginx config is like the sample on this page https://manual.seafile.com/deploy/only_office.html
I use the subfolder solution.
But when I open a Document in seafile, for example a *.docx, I only see a white page without any errors.
I think the problem is that I found the welcome page of onlyoffice under //192.168.1.100:88/welcome/ and not //192.168.1.100:88/onlyofficeds/welcome/
But I don’t know how can I fix it.
Please can you help me?
My Seafile Server Version is 6.1.1 Community
And sorry for my really bad English.
Best regards
NCC1701
Hi @NCC1701 ,
pls post your Nginx config and the OnlyOffice part of seahub_settings
Hi @TMHBOFH
Nginx config
listen 8444 ssl;
listen [::]:8444 ssl;
ssl_certificate /etc/ssl/certs/openmediavault-091d2997-4b49-4472-8c36-e707a73b7137.crt;
ssl_certificate_key /etc/ssl/private/openmediavault-091d2997-4b49-4472-8c36-e707a73b7137.key;
server_name platzhalter.de;
index index.html;
access_log /var/log/nginx/d9b55093-bb1b-415c-ba9c-74399d4b4a27-access.log;
error_log /var/log/nginx/d9b55093-bb1b-415c-ba9c-74399d4b4a27-error.log;
large_client_header_buffers 4 8k;
# seahub
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
fastcgi_read_timeout 36000;
# seafile
client_max_body_size 10G;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
# seafdav (webdav)
location /seafdav {
fastcgi_pass 127.0.0.1:8080;
# onlyofficeds
location /onlyofficeds/ {
proxy_http_version 1.1;
proxy_read_timeout 3600s;
proxy_connect_timeout 3600s;
listen 443 ssl;
listen [::]:443 ssl;
set $root_path "/media/25b019ed-ffb6-45f2-891e-71cdc7f26a39/wordpress";
root $root_path;
index index.html index.php;
set $socket "unix:/var/run/fpm-8c9e09b9-0c1a-4fc2-920a-a739773cac33.sock";
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass $socket;
access_log /var/log/nginx/f1f22075-096d-432a-bdba-88aeb58ccf17-access.log;
error_log /var/log/nginx/f1f22075-096d-432a-bdba-88aeb58ccf17-error.log;
if (!-e $request_filename) { rewrite ^.* /index.php break; }
# set client body size to 256M #
client_max_body_size 256M;
seahub_settings.py
ENABLE_ONLYOFFICE = True
VERIFY_ONLYOFFICE_CERTIFICATE = True
ONLYOFFICE_APIJS_URL = ‘https://platzhalter.de/onlyofficeds/web-apps/apps/api/documents/api.js ’
ONLYOFFICE_FILE_EXTENSION = (‘doc’, ‘docx’, ‘ppt’, ‘pptx’, ‘xls’, ‘xlsx’, ‘odt’, ‘fodt’, ‘odp’, ‘fodp’, ‘ods’, ‘fods’)
mercury
January 22, 2018, 11:49pm
5
I just noticed your post as I’ve been playing with OnlyOffice integration and have been seeing a lot of white pages.
Your setup/configuration is interesting. It seems to combine elements of both the Subdomain and Subdirectory approaches. Which method do you want to use?
Have you solved this problem already?
I also use both, but on a separate server. This works just fine. Long, random subfolder string. Since the token pull request was not yet merged this provides at least some sort of security.
Any news on this topic? I have got exactly the same problem. When i call
https://mydomain :port/onlyofficeds/welcome
i get
https://mydomain :port/welcome
but when i call onlyoffice directly under
http://ip-adress:88/welcome
it works just fine.
THX
themmm
justme
August 8, 2018, 10:56pm
8
Same here. i followed the install thing, and now it says not found, no preview neither editor window but when i call under ipadress:88/welcome it is there, but do i run it on /onlyofficeds/welcome no avail
I’d really appreciate someone shed some light on it.
Thanks and best
jM
If I understand your problems correctly you’ll have to check your nginx config.
The reverse proxy might not be set correctly.
Do you want to run the server under a different port or just as subfolder with :443 where Seafile is running?
