i just upgraded from 6.3 to 7.0.4 CE. In general it works, but there are some problems with seahub.
First, when I try to add comments to a file (right-click on a file and open the comment-sidebar) I get two Error notices in the webinterface, without futher specification.
When I try to add a comment, the same error-notice appears and the comment isn’t saved.
Here are the according lines in the ‘seahub.log’:
2019-08-13 20:52:20,752 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/repos/feb84a36-09e7-449f-b7b9-92ea1ccbe719/file/comments/
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/core/handlers/exception.py", line 41, in inner
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/core/handlers/base.py", line 249, in _legacy_get_response
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/core/handlers/base.py", line 187, in _get_response
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/core/handlers/base.py", line 185, in _get_response
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/views/decorators/csrf.py", line 58, in wrapped_view
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/views/generic/base.py", line 68, in view
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/rest_framework/views.py", line 466, in dispatch
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/rest_framework/views.py", line 463, in dispatch
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/api2/endpoints/file_comments.py", line 65, in get
total_count = FileComment.objects.get_by_file_path(repo_id, path).count()
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/query.py", line 364, in count
return self.query.get_count(using=self.db)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/sql/query.py", line 499, in get_count
number = obj.get_aggregation(using, ['__count'])['__count']
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/sql/query.py", line 480, in get_aggregation
result = compiler.execute_sql(SINGLE)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/sql/compiler.py", line 899, in execute_sql
raise original_exception
OperationalError: (1054, "Unknown column 'base_filecomment.uuid_id' in 'where clause'")
2019-08-13 20:52:20,761 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/repos/feb84a36-09e7-449f-b7b9-92ea1ccbe719/file/detail/
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/api2/base.py", line 23, in dispatch
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/api2/base.py", line 20, in handle_exception
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/api2/views.py", line 3191, in get
comment_total = file_comments.count()
2019-08-13 20:52:24,267 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/repos/feb84a36-09e7-449f-b7b9-92ea1ccbe719/file/comments/
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/api2/endpoints/file_comments.py", line 122, in post
repo_id=repo_id, file_path=path, author=username, comment=comment, detail=detail)
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/base/models.py", line 73, in add_by_file_path
return self.add(repo_id, parent_path, item_name, author, comment, detail)
File "/home/seafile/seafile-server-7.0.4/seahub/seahub/base/models.py", line 65, in add
c.save(using=self._db)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/base.py", line 808, in save
force_update=force_update, update_fields=update_fields)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/base.py", line 838, in save_base
updated = self._save_table(raw, cls, force_insert, force_update, using, update_fields)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/base.py", line 924, in _save_table
result = self._do_insert(cls._base_manager, using, fields, update_pk, raw)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/base.py", line 963, in _do_insert
using=using, raw=raw)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/manager.py", line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/query.py", line 1076, in _insert
return query.get_compiler(using=using).execute_sql(return_id)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/models/sql/compiler.py", line 1112, in execute_sql
cursor.execute(sql, params)
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/backends/utils.py", line 64, in execute
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/utils.py", line 94, in __exit__
File "/home/seafile/seafile-server-7.0.4/seahub/thirdpart/django/db/backends/mysql/base.py", line 101, in execute
File "/usr/lib/python2.7/dist-packages/MySQLdb/cursors.py", line 226, in execute
File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 36, in defaulterrorhandler
raise errorvalue
OperationalError: (1054, "Unknown column 'uuid_id' in 'field list'")
The second issue I have is that I cant edit textfiles in the webinterface anymore. For normal textfiles (e.g. ‘abc.txt’) the edit option doesn’t appear anymore. Or am I overlooking it, is it at a new position?
But even if the editor starts (e.g. when opening *.md-files) is gets stuck in the loading screen.
The following output is created in the ‘seahub.log’:
2019-08-13 21:07:31,338 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/repos/feb84a36-09e7-449f-b7b9-92ea1ccbe719/file/detail/
The other logfiles did not show any information while I was investigating the problems.
Does anyone have a clue or a solution to this problems? I would be very thankful.
Canis Lupus
