Fantastic work! Thank you so much. This is the second Drive update with M1 support for Mac - just wondering, when will you add M1 support for the Sync Client?
I mean the âDesktop Syncing Clientâ not the âDrive Clientâ - the 8.0.0 beta sync client does not have Native M1/Apple ARM support yet. It is this one I am looking forward to.
When I click âCheck for Updatesâ in 2.0.12 it says Iâm up to date. Should I just download the new version off the Seafile site or will the update eventually appear on the existing installed app?
We detected an issue where files /folders had a space at the end of the name (created by macOS) and could not be displayed on windows clients. After removing the space from the name, the drive client shows that the internal database is corrupt. And the drive client also did not list the files in the file sync errors tab as the sync client does.
