That fixed it for me, too.
Thank you!
Could you pls check if you already got the below installed and linked to the correct environment?
apt-get update -y
apt-get install -y libssl-dev
I have installed libssl-dev how should I link it to the environment?
@Jack_Miller any suggestion?
Please provide a properly displayed code example. Ty!
Hello everybody,
6.1.2 to 6.2.1 failed to upgrade SQLlite DB for me :’(
[seafile@birdie upgrade]$ sh upgrade_6.1_6.2.sh
This script would upgrade your seafile server from 6.1 to 6.2
Press [ENTER] to contiune
[INFO] You are using SQLite3
File “/home/sites/teufou.net/seafile/seafile-server-6.2.1/upgrade/db_update_helper.py”, line 363, in
main()
File “/home/sites/teufou.net/seafile/seafile-server-6.2.1/upgrade/db_update_helper.py”, line 358, in main
db_updater.update_db()
File “/home/sites/teufou.net/seafile/seafile-server-6.2.1/upgrade/db_update_helper.py”, line 259, in update_db
super(SQLiteDBUpdater, self).update_db()
File “/home/sites/teufou.net/seafile/seafile-server-6.2.1/upgrade/db_update_helper.py”, line 120, in update_db
self.update_seahub_sql(seahub_sql)
File “/home/sites/teufou.net/seafile/seafile-server-6.2.1/upgrade/db_update_helper.py”, line 283, in update_seahub_sql
self.apply_sqls(self.seahub_db, sql_path)
File “/home/sites/teufou.net/seafile/seafile-server-6.2.1/upgrade/db_update_helper.py”, line 273, in apply_sqls
conn.execute(line)
sqlite3.OperationalError: no such table: sysadmin_extra_userloginlog
Failed to upgrade your database
any suggestion ?
Best Regards
Just a little question: Testing WSGI mode here (with 6.1.2 version, 6.2.1 isnt out for rpi), but thats working fine. The only problem is login page, after typing user and password it didnt redirect to library page. But login works, as if i manually type server adress (which is https://xyz:8001) i get library page. Nginx config is same like posted above, nothing else changed, with fcgi login works normal.
Maybe thats only while using older 6.1.2 version and i have to wait for new 6.2.1? or did i something wrong?
listen 8001 ssl http2;
ssl_certificate /etc/nginx/ssl/###.crt;
ssl_certificate_key /etc/nginx/ssl/###.key;
server_name ###;
server_tokens off;
client_max_body_size 10G; # set max upload size
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_http_version 1.1;
# client_max_body_size 0;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
proxy_request_buffering off;
#location /media {
# root /root/seafile-server-latest/seahub;
location /seafdav {
fastcgi_pass 127.0.0.1:8090;
fastcgi_param HTTPS on;
I’m having the same problem as you and the others are describing. Can you elaborate on this step? Thanks. I’m not exactly sure on how to proceed to carry out what you wrote.
6.2.1 was released as stable before the 14 days of beta time were over. 6.2.1 still has some bugs, hence is still rather beta than stable.
If you state on your website that you run 2 weeks in beta please stick to it. It is not consequent and gives an impression that you don’t care much about what you tell/sell your clients.
Thanks for making CE available to us.
In your nginx config can you reorder the modules this way and see if the error still repeats? I have the same issue with 6.1.2 with Apache.
The order:
location /seafdav
and then
location /seafhttp
It seems to have solved the issue for me: URL rewrite issue. sf.domain.tld/seafdav turns in to sf.domain.tldseafdav
I don’t know why table sysadmin_extra_userloginlog is missing in your sqlite3 db. Anyway, you can create it by yourself via the following sentence:
CREATE TABLE "sysadmin_extra_userloginlog" ("id" integer NOT NULL PRIMARY KEY AUTOINCREMENT, "username" varchar(255) NOT NULL, "login_date" datetime NOT NULL, "login_ip" varchar(128) NOT NULL);
CREATE INDEX "sysadmin_extra_userloginlog_14c4b06b" ON "sysadmin_extra_userloginlog" ("username");
CREATE INDEX "sysadmin_extra_userloginlog_28ed1ef0" ON "sysadmin_extra_userloginlog" ("login_date");
then rerun upgrade_6.1_6.2.sh。
@Captain_Rage I don’t know and have not checked if 6.2.2 fixed this already, but what I had to run was sqlite3 seahub.db < seafile-server-latest/upgrade/sql/6.2.0/sqlite/seahub.sql.
It is for “about 2 weeks”, not for exactly 2 weeks. As the SQLite upgrade script bug is urgent, we publish a new version sooner than waiting 2 weeks. As I don’t see there are other significant bugs, I remove the beta mark.
My bad, didn’t read it this way.
Thanks for the fast fix.
Not fixed in 6.2.2
File “/home/sites/teufou.net/seafile/seafile-server-6.2.2/upgrade/db_update_helper.py”, line 363, in
main()
File “/home/sites/teufou.net/seafile/seafile-server-6.2.2/upgrade/db_update_helper.py”, line 358, in main
File “/home/sites/teufou.net/seafile/seafile-server-6.2.2/upgrade/db_update_helper.py”, line 259, in update_db
File “/home/sites/teufou.net/seafile/seafile-server-6.2.2/upgrade/db_update_helper.py”, line 120, in update_db
File “/home/sites/teufou.net/seafile/seafile-server-6.2.2/upgrade/db_update_helper.py”, line 283, in update_seahub_sql
File “/home/sites/teufou.net/seafile/seafile-server-6.2.2/upgrade/db_update_helper.py”, line 273, in apply_sqls
conn.execute(line)
I will create the table manually
Great It works like a charm
Thank you very much
I have migrated to 6.2 successfully but noticed when using WSGI mode that seahub is exposed on port 8000 on 0.0.0.0 not 127.0.0.1. As I’m on a VPS with no iptables this is a problem.
Looking in seahub.sh there is this line:
$PYTHON $gunicorn_exe seahub.wsgi:application -c “${gunicorn_conf}” -b “0.0.0.0:${port}” --preload
I have changed the 0.0.0.0 to 127.0.0.1 which works for me. Is there another way which is more suitable?
(BTW must try and learn to format code in these fancy editors on day)
EDIT: Just noticed user TMHBOFH has also spotted this.
Best Regards
For people not configured Nginx/Apache, ./seahub.sh start need to listen on 0.0.0.0 to work. For not broken existing Seafile installations, this should be default behaviour. We will add an option to listen on 127.0.0.1 only.
Excellent Daniel.
Thank you.
Not sure I follow. Are you saying we should modify seahub.sh for 127.0.0.1, modify Nginx config (or Apache) or wait for an update? -Thanks
