I noticed that you made a Git project on a Seafile zimlet for Zimbra
Is this code experimental or is it to be used on a production server ?
What are the requirements (Zimbra and Seafile versions) ?
What are the features ? Is is limited to file attachements when editing messages ?
Are the files only attached to the message or can we also send sharing links (for files and folders) ?
We are testing a small patch against the āblobā problem.
It seems that when the frame for shibboleth authentication is displayed,
the showAttachementSaveDlg function is called a second time but with empty arguments.
Weāll give our small (and dirty) code if it is confirmed.
zimbra supports NextCloud and OwnCloud the project on git: https://github.com/haiwen/seafile-zimlet for Seafile did not change since 2016. Has someone a working konfiguration or integration ?
The development of the haiwen zimlet has stopped in 2016.
But we asked Barry de Graaff to enhance the Zimbra-Community zimlet to support also seafile and he did it. Here is the link to the annoucement: New Zimbra plugin for Seafile Server.
If there is any feature inside the haiwen zimlet that is not yet support by the new one we will make sure that this feature will be merged.
