Meanwhile I increased the verbosity of seadrive logfile by setting the environment variable ‘SEADRIVE_DEBUG’ to ‘fs’. I have added an extract from my current log file below.
[02/12/20 13:23:49] seadrive.c(697): Starting SeaDrive client 1.0.11
[02/12/20 13:23:49] seadrive.c(699): SeaDrive client source code version 3be507ed9efdd600e90c0311b8cc5f24e73cac41
[02/12/20 13:23:49] seadrive.c(725): rpc server started.
[02/12/20 13:23:49] seadrive.c(740): Limit access to current user session only.
[02/12/20 13:23:49] seafile-session.c(401): Moving blocks for deleted repo 782bb52f-8b5c-41cd-a45c-f10798ab944c.
[02/12/20 13:23:49] seadrive.c(745): Mount virtual drive as removable disk.
[02/12/20 13:23:49] dokan-ops.(2689): GetVolumeInformation called.
[02/12/20 13:23:49] repo-mgr.c(1301): Removing store C:/Users/????/seadrive/data\deleted_store\blocks\782bb52f-8b5c-41cd-a45c-f10798ab944c
[02/12/20 13:23:49] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x800021
[02/12/20 13:23:49] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:23:49] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:23:49] dokan-ops.(2398): Close \ called.
[02/12/20 13:23:49] dokan-ops.(2769): Mounted called.
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \ called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:23:50] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:23:50] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:23:50] dokan-ops.(2398): Close \ called.
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100081, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x20
[02/12/20 13:23:50] dokan-ops.(605): FindFiles \ called.
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \Für alle freigegeben called. desired_access: 0x100081, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x20
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \Für meine Gruppen called. desired_access: 0x100081, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x20
[02/12/20 13:23:50] [02/12/20 13:23:50] dokan-ops.(323): GetFileInformation \Für alle freigegeben called.
dokan-ops.(323): GetFileInformation \Für meine Gruppen called.
[02/12/20 13:23:50] dokan-ops.(605): FindFiles \Für alle freigegeben called.
[02/12/20 13:23:50] dokan-ops.(605): FindFiles \Für meine Gruppen called.
[02/12/20 13:23:50] [02/12/20 13:23:50] dokan-ops.(2333): Cleanup \Für meine Gruppen called.
dokan-ops.(2333): Cleanup \Für alle freigegeben called.
[02/12/20 13:23:50] [02/12/20 13:23:50] dokan-ops.(2398): Close \Für alle freigegeben called.
dokan-ops.(2398): Close \Für meine Gruppen called.
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \Für mich freigegeben called. desired_access: 0x100081, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x20
[02/12/20 13:23:50] dokan-ops.(323): GetFileInformation \Für mich freigegeben called.
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \Meine Bibliotheken called. desired_access: 0x100081, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x20
[02/12/20 13:23:50] dokan-ops.(323): GetFileInformation \Meine Bibliotheken called.
[02/12/20 13:23:50] dokan-ops.(605): FindFiles \Für mich freigegeben called.
[02/12/20 13:23:50] dokan-ops.(605): FindFiles \Meine Bibliotheken called.
[02/12/20 13:23:50] dokan-ops.(2333): Cleanup \Für mich freigegeben called.
[02/12/20 13:23:50] dokan-ops.(2398): Close \Für mich freigegeben called.
[02/12/20 13:23:50] dokan-ops.(2333): Cleanup \Meine Bibliotheken called.
[02/12/20 13:23:50] dokan-ops.(2398): Close \Meine Bibliotheken called.
[02/12/20 13:23:50] dokan-ops.(323): GetFileInformation \Für meine Gruppen called.
[02/12/20 13:23:50] dokan-ops.(2333): Cleanup \Für alle freigegeben called.
[02/12/20 13:23:50] dokan-ops.(2398): Close \Für meine Gruppen called.
[02/12/20 13:23:50] [02/12/20 13:23:50] dokan-ops.(2333): Cleanup \Für mich freigegeben called.
[02/12/20 13:23:50] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:50] dokan-ops.(2689): GetVolumeInformation called.
[02/12/20 13:23:51] start to serve on pipe client
[02/12/20 13:23:52] start to serve on pipe client
[02/12/20 13:23:54] repo-mgr.c(2588): switching account to https://example.org ???@???.
[02/12/20 13:23:54] start to serve on pipe client
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \ called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:23:54] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:23:54] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:23:54] dokan-ops.(2398): Close \ called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:54] dokan-ops.(605): FindFiles \ called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x800021
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Für alle freigegeben called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:23:54] dokan-ops.(323): GetFileInformation \Für alle freigegeben called.
[02/12/20 13:23:54] dokan-ops.(2333): Cleanup \Für alle freigegeben called.
[02/12/20 13:23:54] dokan-ops.(2398): Close \Für alle freigegeben called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Für alle freigegeben called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:54] dokan-ops.(605): FindFiles \Für alle freigegeben called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Für meine Gruppen called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:23:54] dokan-ops.(323): GetFileInformation \Für meine Gruppen called.
[02/12/20 13:23:54] dokan-ops.(2333): Cleanup \Für meine Gruppen called.
[02/12/20 13:23:54] dokan-ops.(2398): Close \Für meine Gruppen called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Für meine Gruppen called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:54] dokan-ops.(605): FindFiles \Für meine Gruppen called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Für mich freigegeben called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:23:54] dokan-ops.(323): GetFileInformation \Für mich freigegeben called.
[02/12/20 13:23:54] dokan-ops.(2333): Cleanup \Für mich freigegeben called.
[02/12/20 13:23:54] dokan-ops.(2398): Close \Für mich freigegeben called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Für mich freigegeben called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:54] dokan-ops.(605): FindFiles \Für mich freigegeben called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Meine Bibliotheken called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:23:54] dokan-ops.(323): GetFileInformation \Meine Bibliotheken called.
[02/12/20 13:23:54] dokan-ops.(2333): Cleanup \Meine Bibliotheken called.
[02/12/20 13:23:54] dokan-ops.(2398): Close \Meine Bibliotheken called.
[02/12/20 13:23:54] dokan-ops.(1170): CreateFile \Meine Bibliotheken called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:54] dokan-ops.(605): FindFiles \Meine Bibliotheken called.
[02/12/20 13:23:55] sync-mgr.c(1457): All repo fs trees are loaded.
[02/12/20 13:23:55] sync-mgr.c(586): Repo 'Meine Bibliothek' sync state transition from 'synchronized' to 'committing'.
[02/12/20 13:23:55] sync-mgr.c(2727): All operations of repo Meine Bibliothek(148145f6) have been processed.
[02/12/20 13:23:55] sync-mgr.c(586): Repo 'Meine Bibliothek' sync state transition from 'committing' to 'synchronized'.
[02/12/20 13:23:56] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:23:56] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:23:56] dokan-ops.(2689): GetVolumeInformation called.
[02/12/20 13:23:56] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:23:56] dokan-ops.(2398): Close \ called.
[02/12/20 13:24:00] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:24:00] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:24:00] dokan-ops.(2689): GetVolumeInformation called.
[02/12/20 13:24:00] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:24:00] dokan-ops.(2398): Close \ called.
[02/12/20 13:24:49] file-cache-mgr.c(2645): cache size limit is 10000000000
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:25:56] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:25:56] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:25:56] dokan-ops.(2398): Close \ called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \ called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:25:56] dokan-ops.(605): FindFiles \ called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x800021
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Für alle freigegeben called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:25:56] dokan-ops.(323): GetFileInformation \Für alle freigegeben called.
[02/12/20 13:25:56] dokan-ops.(2333): Cleanup \Für alle freigegeben called.
[02/12/20 13:25:56] dokan-ops.(2398): Close \Für alle freigegeben called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Für alle freigegeben called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:25:56] dokan-ops.(605): FindFiles \Für alle freigegeben called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Für meine Gruppen called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:25:56] dokan-ops.(323): GetFileInformation \Für meine Gruppen called.
[02/12/20 13:25:56] dokan-ops.(2333): Cleanup \Für meine Gruppen called.
[02/12/20 13:25:56] dokan-ops.(2398): Close \Für meine Gruppen called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Für meine Gruppen called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:25:56] dokan-ops.(605): FindFiles \Für meine Gruppen called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Für mich freigegeben called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:25:56] dokan-ops.(323): GetFileInformation \Für mich freigegeben called.
[02/12/20 13:25:56] dokan-ops.(2333): Cleanup \Für mich freigegeben called.
[02/12/20 13:25:56] dokan-ops.(2398): Close \Für mich freigegeben called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Für mich freigegeben called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:25:56] dokan-ops.(605): FindFiles \Für mich freigegeben called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Meine Bibliotheken called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:25:56] dokan-ops.(323): GetFileInformation \Meine Bibliotheken called.
[02/12/20 13:25:56] dokan-ops.(2333): Cleanup \Meine Bibliotheken called.
[02/12/20 13:25:56] dokan-ops.(2398): Close \Meine Bibliotheken called.
[02/12/20 13:25:56] dokan-ops.(1170): CreateFile \Meine Bibliotheken called. desired_access: 0x100001, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x21
[02/12/20 13:25:56] dokan-ops.(605): FindFiles \Meine Bibliotheken called.
[02/12/20 13:26:05] dokan-ops.(1170): CreateFile \ called. desired_access: 0x80, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x200000
[02/12/20 13:26:05] dokan-ops.(323): GetFileInformation \ called.
[02/12/20 13:26:05] dokan-ops.(2333): Cleanup \ called.
[02/12/20 13:26:05] dokan-ops.(2398): Close \ called.
[02/12/20 13:26:05] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x800021
[02/12/20 13:26:05] [02/12/20 13:26:05] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100000, share_access: 3, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x800021
[02/12/20 13:26:05] dokan-ops.(1170): CreateFile \desktop.ini called. desired_access: 0x120089, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x64
[02/12/20 13:26:05] dokan-ops.(1170): CreateFile \ called. desired_access: 0x100081, share_access: 7, file_attributes: 0x0,create_disposition: 0x3, create_options: 0x20
[02/12/20 13:26:05] dokan-ops.(605): FindFiles \ called.
@daniel.pan Does this give any indication of the problem?
